Quick Tips: How to Group, Ungroup and Subtotal
dbrandywatling
0 0 20
Do you ever use standard reports that has subtotaling or grouping that you want to remove for better analysis? Or, do you want to add grouping and subtotaling for easier review when you send reports to managers? This is the perfect video for you then. This video will show you the step-by-step process to add or remove subtotaling and grouping.
