Who Me Too'd this topic
mweissBP
Flight Search Showing Limited Departure Times by Default
I’ve noticed a change in how flight search results are being displayed in Concur and wanted to check if this is due to a recent update or a setting on my end.
Previously, flight searches defaulted to “Anytime.” However, as of this week, searches are defaulting to a limited departure window of 1:00 AM–5:00 PM.
Even when I update the departure time to “Anytime” using the dropdown on the search result screen, the results still only display flights up to 5:00 PM.
After some digging, I found a separate (less visible) departure time setting within the calendar window. When I change that setting to “Anytime,” the results update correctly. However, if I then modify airports within that same window, the departure time resets back to 1:00 AM–5:00 PM.
Can you confirm:
  • Whether this is the result of a recent update?
  • If there is a way to restore “Anytime” as the default search setting?
This workflow has become quite frustrating, as I now need to repeatedly adjust the time filters - not just for the initial search, but for subsequent searches as well. Since I typically compare flights across multiple nearby airports, this adds a significant amount of extra time.
Thanks in advance for your help.
