souradip_dutta
Not able to connect Concur APIs
I am exploring SAP Concur APIs in Test Instance.  Using ClientID, ClientSecret and my User credentials I am able to generate access_token. I tried 1st api call profile/v1/me and it was successful. Then I tried making other api calls like '/travelrequest/v4/requests?view="ALL"&limit=10&start=0', '/profile/identity/v4/Users' all failed got error 401 unauthorized or 403 UserIsNotAllowed. Though I have highest level of permission for Request and Expenses in SAP Concur.
Please suggest me what can be possible reasons for this failures.
Thank You,
Souradip Dutta
Andras
Hi @souradip_dutta , as a part of ICS, I did not hear about Bear token... looks like this something  Web Services related. Can you please try to generate a new token or try to use request token?
In case it did not help, I would recommend opening support case for Web Services Team.
Let me know about the results.
Best wishes,
Andras
Andras
Hi @souradip_dutta
Please check the attached screenshot. These are the common errors and their meaning.
Do I understand correctly that you are using web services?
Best wishes,
Andras
crystalreports
souradip_dutta
@Andras Yes, I am using Web services and I was using Bearer token.
As I understand Bearer token can be used to connect v1-v3 apis. I will need Company JWT token to connect v4 apis.
But using a valid Bearer token I tried calling "https://us2.api.concursolutions.com/api/v3.0/expense/reports"
Still I am getting 403 forbidden error.
Andras
Best wishes,
Andras
souradip_dutta
We have raised a support case with Web Service team. Thank You.
