JonahG
Issues when opening concur in microsoft edge
I am having an issue where when I use concur in firefox it will open the contents in a new tab and have the interactive editing buttons like the picture below. When I open the device in Microsoft Edge, it will not show any of these interactive buttons. How can i get these to show in edge? Our IT department will be removing firefox/chrome soon.
8 REPLIES 8
MelanieT
@JonahG Hi Jonah!  Is issue only occurring when you are using Cognos?  Or SAP Concur in general?
Melanie Taufen
JonahG
@MelanieT Hey Melanie! I believe that it is just the Cognos platform as that is used for reporting.
@JonahG hello there. Your screenshot is from accessing Cognos Reporting or Analysis, correct? What I'm confused about is when I looked up your profile, you don't have the permission on your profile to access Analysis.
Is there another profile you use or some clarification you can provide that explains how you are seeing the screen in your screenshot? 🙂
MelanieT
@JonahG  Thanks, I just wanted to make sure.  Here are browsers that are Supported.  Let me know if this helps at all or not 🙂
COGNOS 11:
The new platform is now supported on major browsers such as:
  • Google Chrome
  • Mozilla Firefox ESR
  • Apple Safari
  • Microsoft Edge (including Report Studio now known as "Report" in Cognos 11)
You can create or edit in Cognos Report, in Firefox or Google Chrome. But if you are using Cognos Query Studio you need to use Firefox.
A full list of supported environments and minimum requirements for IBM Cognos can be found here
COGNOS 10
For reading or running reports, you may use Google Chrome, MS Edge, etc.
If you wish to create or edit reports in Cognos, you will need to use one of the following browsers:
  • Internet Explorer (IE10 and IE11 are only supported in compatibility mode)
  • Firefox ESR version.
Google Chrome is not supported for editing reports.
For Internet Explorer, please check: How do I add Concur to Compatibility View in Internet Explorer?
Melanie Taufen
JonahG
@MelanieT Hey Melanie! This is very helpful, so according to this, you need chrome or firefox to edit reports and edge does not work to do so. Is there plans to allow edge to edit reports?
MelanieT
@JonahG I don't believe at this time they are planning this, but this would be something you could submit as an improvement request. To submit a new improvement request or vote on an existing improvement request, please visit the Customer Influence Website.
Melanie Taufen
SharronL
Now we are in 2025, is it still the case that you can only edit Concur Analysis reports using Google Chrome or Firefox Browsers?
@SharronL I believe so. This has been a long standing issue with IBM and their Cognos offering.
