LindaNBay
How can I tell if Acct is locked? Tried to chg Password & then log in. No email reply or QR
History: I Tried to chg Password & then log in under the new 2FA.
  • A screen poped up with QR, then disappeared.
  • Now, when I try to log in, it says it will send me an email to log in with. No email reply from Concur has been received in New Mail or SPAM .  No screen with a QR has popped up, since the first attempt of logging in under 2FA.
  • I  sent 3 emails to my agency, but have not received a reply.  I gather they are new to this kind of 2 factor authentication.
Questions
#1.  Is there anyway to contact Concur directly, and ask them to reset my login?
#2.Can an agency, request other than a 2 factor authentication? How do they do it?
#3. How can I tell if  my Acct is locked?
 #4. Is there a way to find out who is our agency admin (our agency changes roles yearly and it maybe the person from last year).  You can message me and I will give you the Toastmasters group name.
MelanieT
@LindaNBay
#1.  Is there anyway to contact Concur directly, and ask them to reset my login?   Yes, I can send you this contact info in a private message to you.
#2.Can an agency, request other than a 2 factor authentication? How do they do it? If you are using Single Sign on, you do not need 2FA, however if your company does not, you will need to use the 2FA.
#3. How can I tell if  my Acct is locked? You should get a pop up message stating you are locked out.
 #4. Is there a way to find out who is our agency admin (our agency changes roles yearly and it maybe the person from last year).  You can message me and I will give you the Toastmasters group name.  I will see if I can find that and send in a private message.
Melanie Taufen
cjmarimo
@LindaNBay
Your company admin could restart your password and 2FA.
I think You need your has verified your email1 in your Concur Settings profile to receive password or 2FA email.
BR,
cj
  Best Regards,
  CJ
LindaNBay
Thanks so much.  Could you tell me who the admin is for District57 Toastmasters (aka-d57tm)
