lzconcep
Exporting from List Management
Does anyone know where I can find the instructions for how to export data from "List Management" in Professional Version?
2 Solutions
Hi @lzconcep ,
There is no option to export list items from list management.
However, if needed you can export list items by creating custom report in Cognos.
lzconcep
@PoojaKumatkar  Thank you Pooja.  That was going to be my next step, but I though I'd ask first if there maybe an easier and readily available option.
grodriguezproje
lzconcep
Hi @grodriguezproje
I just checked it and there is no instruction any where on how I can eXport the data.  I see the import button and that is it.
Hi @lzconcep ,
lzconcep
mhanel
I am new to creating a custom report in Cognos, if anyone has the time, can you send instructions on how to create a report for List Management?
Very much appreciated!
Hi @mhanel ,
Role Required - Cognos Professional Author
1. Click on Content folder >> click on New + button (top right corner) >> Click on Report >> click on Create button
2. Select a Source + (left hand side pane blue button) >> pop up window appears >> select Concur Data warehouse >> click on Open button
3.  From the middle pane select a widget type "List" >> pop up window >> click ok
4. From left side pane >> expense "Expense" folder >> Expand "Lists" folder >> Expand "Custom and Connect Lists" folder
5. Drag and drop fields - List, List Item, List Item Short Code, List Level (optional and if list is connected list), List Item Deleted Flag (optional)
6. Once drag in table >> select List column header and apply filter to search for the list name.
Hope this helps.
