The message you are trying to access is permanently deleted.
I did not originally setup our SSO certs so I inherited this application and as of 5/3/25 our current Microsoft Entra SSO certification for Concur has expired. I went into Microsoft Entra\enterprise applications\concur and created a new SAML signing certificate and made it active. I didn't change any of my basic or attributes & claims inside of Entra. I downloaded the Metadata from entra. I then connected to Concur and accessed the authentication admin screen. I left the SSO settings to sso optional and downloaded the SAP Concur Metadata. I didn't have anything setup under SSO configurations so I added an IdP config with our IdP name, login url, and the metadata from entra that I downloaded previously. When I test the application in Entra I get that a token (saml response) was successfully issued. When I try and access the application via our sign on url I get a misconfigured application error. Is anyone else having this issue after your SAML certification expired?
I figured out my problem. The original setup was built before an enterprise application was available and it not tied correctly to the concur authentication. I completely rebuilt the application in entra. Now my only problem is that it asks for user id and then password instead of just using the synced credentials from your browser.
