watchison
Expense report
Can someone direct me on how to get to the Expense report?
Thank you
MSteele
Once you're in Concur, look for HOME in the upper left of the screen.  Click the drop down menu and you should see Expense.  If you don't see this, I suggest contacting your Administrator as you may not be set up for Expense.
