TravelGirl
2FA Setup for Apple (Mackbook Air)
This was the best solution for me that worked:
  • Go to “Apple () menu > System Settings>  Passwords > then add the Concur login website > once entered you should be able to enable 2FA and see the code and then copy and paste it into Concur
@TravelGirl thank you for posting this. 🙂
