- Mute
- Subscribe
- Bookmark
OAuth 2.0 Application Management not visible
Dear Gurus,
We are trying to establish API connection with Concur however we notice under Authentication administration we don't see OAuth 2.0 Application management. Is this due to version we had or authorization. We do have web services role assigned.
Ming
- Mute
- Subscribe
- Bookmark
@mhlow7 Thanks for posting in the SAP Concur Community. I would recommend that you check the OAuth2 Migration Best Practices page to see determine if you are using the New World Authentication Oauth2. If you have questions, I would recommend opening a case in the SAP Concur Support Portal for an expert to guide you through the questions or process.
Lee-Anne Dautovic
- Mute
- Subscribe
- Bookmark
I'm encountering same issue. trying to create OAuth app but the option is not visible. I can confirm web services role is assigned for the user.
- Mute
- Subscribe
- Bookmark
@asha17 you might be missing a certain permission to see this. Submitting a help ticket to Concur Support is your best option to get the correct permission or to see if there is some issue.
