sumantp
Pick-up time field not there
I’m trying to book ground transport but the field to specify pick-up time isn’t there. It doesn’t let you proceed without specifying the pick-up time.
8 REPLIES 8
@sumantp could you provide some screenshots please?
sumantp
As you can see in the attached screenshot, there’s no place to specify the pickup time.IMG_5113.jpeg
@sumantp what happens when you click the little arrows next to Pick-up Time? I would think this would have a drop-down of possible times. Also, did you mouse over the Tool tip (?) next to this field to see what it says?
sumantp
@KevinD "Pick-up time" is the only choice in the dropdown list. The hover-over just says that I need to specify a pickup time. I've used this screen before and it has worked. This behavior is new.
@sumantp thank you for this. Odd behavior indeed. Did you try using a different browser? Give that a try just to see if you have the same issue. I'll post your screenshot internally to see if anyone can provide some details.
sumantp
The behavior is the same across multiple browsers, both on laptops and mobile devices.
@sumantp I would suggest submitting a help ticket to Concur Support as it sounds like a bug to me.
rdaveslaw
Same view as above.  using google chrome:
