Independent hotel, Hotel is in GDS but Concur cannot pull it, I assume there may be a communication or mapping problem between Concur and the GDS. Unsure how to check that the property ID and chain code are correct in Concur’s system? Or further steps to figure this out?
Topic: Independent hotel not showing in Concur database
If an independent Hotel is available in the GDS but not appearing in Concur, perform the below checks:
GDS property IDs and Chain Codes are maintained by the GDS/Content Provider and not directly in Concur Travel. Concur Administrators cannot directly edit GDS hotel property IDs or Chain Codes.
There is NO Universal Concur Administrator screen for directly maintaining GDS Hotel Property IDs and Chain Codes.
Thanks & Regards
Samantha Prathikantam
I do not have access to Concur, just this community, so I am unsure how to escalate this. I know I had the same problem with DTS (essentially, the militaries version of Concur) and our GDS codes were missing from the database but once updated we were then bookable. I assume this is the case here as well.
@cmarshallccl SAP Concur pulls published rates from the GDS. We can only show what the GDS is providing. So, likely the issue is with the hotel's rates not being in the GDS.
