"Supplier Travel" not a drop down reason for Travel when booking.
Topic: "Supplier Travel" not a drop down reason for Travel when booking.
If “Supplier Travel” is missing from the SAP Concur Travel dropdown when booking, check the below.
Check:
Administrator Navigation: The exact Configuration Path depends on whether Reason for Travel is a:
1. Custom Field
2. Configured List or
3. Part of a Booking Workflow.
“Supplier Travel” is not a standard Concur value.
It may be a Company-Specific value that requires Configuration or Activation.
Thanks & Regards
Samantha Prathikantam
@Scott_Revels I take it your company is requiring the Reason for Travel.
What is available in the drop down?
