PBlanco
Errror Code ar-40212
One of my travelers is trying to book a one-way flight from Chicago to Miami on November 11th via United Airlines and is getting the error message "ar-40212". I went through the process with her and made sure her profile is updated, but the error continues. Any recommendations?
@PBlanco I looked up our list of error codes and the description for this was, how do I say, less than helpful. The description simply says, "unable to book".
Anyway, my suggestion is to call the travel agency to get the booking done.
JonC
Hi, Just adding some info incase it helps in future.
We just had a couple of people with the same error when booking flights.
After some trial and error, they were able to book if they choose Not to select seats when creating the booking
MartinB
I just encountered the same error while booking flights in Concur. I also removed the seat selection and retried, but unfortunately the issue persists.
Are there any other troubleshooting steps or workarounds you would recommend?
Thanks for your assistance.
MartinB
Sorted. The issue was caused by an extra space in my name. Once I updated it to exactly match my passport and used only a single credit card, the booking went through successfully.
