Meike123
E-Invoicing Germany
with the new Wachstumschancengesetz the e-invoicing becomes obligatory in Germany. This means from 01.01.2025 a customer needs to be able to receive an AP invoice in an electronic data format. As far as I know, common invoice formats are XRechnung, Zugferd and EDI. How can we receive and process such invoices in Concur? Is there a solution for it? Google does not bring any results...
Thanks and regards,
Meike
16 REPLIES 16
MelanieT
@Meike123  I am asking our Invoice team and will update you once I hear back from them.
Melanie Taufen
TriciaW
@Meike123 Hello and thank you for posting your question on the SAP Concur Community.  Currently, E-invoicing regulations that SAP Concur supports are:
  • Concur Expense: Mexico’s Comprobantes Fiscal Digital por Internet (CFDI)
  • Concur Invoice: PEPPOL support in Australia, New Zealand, and Japan
Your SAP Concur Admin should be able to reach out to their Account Manager for any future roadmap enhancements.
Tricia Whipps
SAP Concur Select Care Community Moderator
Meike123
@TriciaW  Will there be a solution for all your German customers? As law will be effective as of 01/01/2025 this would require an urgent action.
TriciaW
@Meike123 Hello.  I was able to find out from our Product team, businesses will need to be able to receive e-invoices by 2025 in Germany, however it won’t become fully mandatory for business to issue e-invoices in Germany until 2027.
Since the ability to receive e-invoices is relevant beyond solely T&E costs, it would be interesting to know how the our customer organizations intend to receive e-invoices for all their expenses– do you plan to retrieve invoices via government approved portals directly or will you contract with a partner to retrieve the e-invoices?    This would be useful feedback to give to our team.
Currently there is some work being done to help our customers with some of these requirements.  More to come in future release notes.
Tricia Whipps
Meike123
@TriciaW Thanks for your reply.
Does that mean that SAP is working on a solution for concur to meet those new requirements?
Unfortunately I have no idea how this will work and where we get the data from, so I cannot give any input to that.
apaterson009
@TriciaW Keen to understand how SAPConcur will meet this requirement effective 1/1/2025.
At present our users are able to upload the following file types as a "receipt" with their expenses claims "Valid file types for upload are .png, .jpg, .jpeg, .pdf, .tif or .tiff.
5MB limit per file."
Will the new file formats be allowed to be uploaded in a future release? Can you provide further details on the planned developments please.
MarekSwiderskiR
Hi @TriciaW
I am also interested in this topic.
Do you have any insights about it since April?
Thank you
@MarekSwiderskiR this enhancement to meet the German requirement is coming soon. I emailed someone internally to see if we have a date yet.
KarolinaPD
Hello Kevin,
Did You manage to receive any news regarding e-invoicing for Germany?
Best regards,
Karolina
@KarolinaPD we have a post here on Community about it. https://community.concur.com/t5/What-s-New-in-Product/Navigating-Germany-s-New-E-Invoicing-Regulatio.... 🙂
Mic_Lamers
Thank you Kevin!
We use SAP Concur for Invoice. What will be the solution there for processing e-invoices? They are currently not picked-up by Concur Capture.
Mic
bhubbell
Hi - You need to license SAP Document Compliance BTP application and then enable Peppol integration in that tool.  There are numerous steps in BTP setup steps to setup a cloud found sub account, create destinations to Concur (you need two production and UAT).   Once complete, you need to enable Document compliance in the Concur App Center.  And do the additional setup in Concur Invoice configuration to map this into a default Supplier/vendor, default email, default workflow policy.  It's a lengthy process and seems to work in Test and Production but not both at the same time
Bruce H
Mic_Lamers
Thank you @bhubbell. Unfortunately I never received notification of your response.
By now we have decided on a global solution for e-invoicing since SAP does not (yet) cover all our country mandates. But we do need to integrate with Concur, so currently looking into WS and post to Concur API endpoint.
To better understand the process though, does anyone know where the e-invoices for Germany or other countries end up in Concur UI? Assuming that will also be a separate view in the UI that we currently do not see, is that correct?
Much appreciated if anyone already has the experience from either BTP/SAP DRC or posting invoice through API sharing their experience!
Mic
bhubbell
Hi Mic,
They end up in Concur Capture view for final coding.  Concur Capture is used if you are receiving invoice via a capture mailbox.
The Concur Doc Compliance integration only maps to one vendor per connection, and doesn't code anything to expense types.  Things like a default ledger are added by Concur, a default location needs to be setup, and a default vendor is configured by you if you have the right access. You have to be concur certified to even see some of the configuration.  So once received Invoices need further coding in Concur Invoice.
Best of luck
Bruce H
RHundertmark
Hello all,
There is a document called "SAP Concur Taxation Framework Roadmap" of July 2025 that has information regarding the tax handling of e-receipts/e-invoices for Concur.
As I the document says it is confidential, I think it is wise to contact your Concur account manager for this document.
Remco
AhmetBalik
Hello all,
As described below I have done the necessary steps for test purposes as an admin
  https://community.concur.com/t5/What-s-New-in-Product/Navigating-Germany-s-New-E-Invoicing-Regulat...
So basically receipts@concur.com this E-mail address is not working at all for both Zugferd and xml receipts. I've contacted Sap Support regarding to it, they've asked me to try to send the receipts to  receipts@expenseit.com .
So:
- Zugferd is working if you send the invoices to receipts@expenseit.com
-Xml receipts ( without converting it to PDF or JPEG) is not working
What i wanted to say is, XML receipts should also work like Zugferd without converting them to any other format. That is for us totally unacceptable. We can't expect from our employees to do an extra work just to handover their receipts.
I'm expecting from Concur a solution to solve this nonsense.
Regards
Balik
