I have an erroneous expense that CitiBank did not process within the allotted timeframe, but which has now been processed. I've already submitted the expense for that period, but need now to submit this single expense. So, how can I retrieve the original itinerary to attach it to the single expense?
Hi em451f
Please try the below. Hope it helps.
Since CitiBank processed the corporate card charge after you had already submitted your original expense report, you can generally submit the delayed transaction in a new SAP Concur expense report and attach the original travel itinerary as supporting documentation.
Step_1: Retrieve the original itinerary
If the trip is no longer visible, check your original booking confirmation email or contact your Travel Management Company (TMC).
Step_2: Submit the delayed CitiBank Transaction
Suggested Comment:
This expense relates to a previously completed business trip. The CitiBank corporate card transaction was processed after the original expense report had been submitted. The original travel itinerary is attached for reference. This charge was not included in the earlier report.
Important: Verify that the expense was not already reimbursed or included in the original report. Also, an itinerary may support the travel purpose but does not necessarily replace a required itemized receipt.
Alternative: If the itinerary is unavailable in Trip Library, check the original expense report's attachments or request a copy from your company's travel administrator.
This approach allows you to reconcile the late-posted transaction without reopening the previously submitted report, subject to your company's expense policy.
Thanks & Regards
Samantha Prathikantam
Hi Samantha,
thank you for a very detailed and easy to follow solution.
With Regards
Barry Jessel
@em451f if the itinerary item was already submitted on another report, it cannot be retrieved. What is the expense in question? I'd like to take a look at your reports and expenses to see what options you have.
Hi em451f
Suggested Comment:
Thanks & Regards
Hi Samantha,
With Regards
Barry Jessel
a solution was already offerd and I have resolved my issue.
Thank you so much for responding.
Regards
Barry
