btinkle
SAP Concur Webinar: Joule Essentials Session
Does anyone know where we can access the following webinar?  I was not sent an email with the recording and there were some interesting items in it.
Hi @btinkle ,
You can check below webinar link and search for Joule Essentials Session
https://www.concur.ca/events?utm_source=chatgpt.com
Upon checking I observed that it was a scheduled session on February 5, 2026. When registering for an SAP Concur webinar (like this one), you should have received a confirmation email with a link — that same link often becomes the on-demand replay link once the session ends. If you can’t find that email, check your Spam/Junk folder and search for mail from [email protected].
Note - This information I got online while looking for the webinar information. Please try to check your Spam/Junk folder as suggested above for the above mentioned email.
btinkle
Thank you Pooja, I have my registration email but the only link is to the actual webinar which does not work.
Hi @btinkle ,
Let's take Kevin's help here.
@KevinD - Does anyone from your team can help here to get that session recording link for him. As he registered for this session, atleast he should have received that link.
btinkle
Thank you Pooja and Kevin!
@btinkle I wasn't aware of this webinar and that it was even taking place. I don't know where to start looking.
I would suggest emailing [email protected] and ask them if they can provide a link.
btinkle
Also, I used the link above and when I found the webinar, it took me to registration
