sallyfab
'Location worked' not propagating to expense itemization tab
I entered the 'location worked' on the expense details tab for my hotel, but the field is not propagating to the itemization line items. I am getting alerts saying that the location worked is missing from the 'hotel' line items in the itemization tab, but the field is greyed out on the itemization tab so I can't enter anything there. I can delete it and re-enter 'location worked' on the details tab, save the expense, but that field does not propagate to the itemization tab.
How can I force it to propagate that field through to the itemization tab? Thank you.
sallyfab
@MelanieT  Hi, Thank you for your feedback! I did receive guidance from a support person. There does seem to be an issue with concur, but until it gets fixed, he just found a workaround: delete the items where the 'location worked' did not propagate and re-create them manually and then the 'location worked' propagated correctly to the itemized lines items.
rohanpatil
Hi @sallyfab
This seems like a copy down source configuration issue and would normally impact multiple users.
my suggestion is to report to your Helpdesk support team or Concur administrator. Hope this helps.
Rohan Patil
sallyfab
@rohanpatil Hi, Thank you for your feedback! I did receive guidance from a support person. There does seem to be an issue with concur, but until it gets fixed, he just found a workaround: delete the items where the 'location worked' did not propagate and re-create them manually and then the 'location worked' propagated correctly to the itemized lines items.
@sallyfab Glad that you have a workaround. Unfortunately with cloud products, we have to live with some workarounds.
Rohan Patil
MelanieT
@sallyfab I am sorry for the issues on your report!  I did go in and it looks like you were able to resolve this, can you confirm?
Melanie Taufen
sallyfab
MelanieT
@sallyfab Excellent!  I am so glad you found the workaround for now!  Have a great week ahead!
Melanie Taufen
