- Mute
- Subscribe
- Bookmark
I submitted my Nov exp rept then found another receipt that I didn't include. How to fix?
- Mute
- Subscribe
- Bookmark
Hi @cupshur
Check if you can recall the expense report:
- Go to Concur
- Go to Expense
- Go into the sent expense report
- Upper right hand you will se a blue button "Recall Report"
If the recall button is missing, check the following options:
- Contact your Finance & Admin department or IT Concur Admin, and ask them if they can recall the report from being posted.
- Once they recall the expense report, you will be able to recall it by yourself.
If non of the above approaches are possible, check the following:
- Create a new expense report for this receipt (if your company allow more than one report per month)
- Include the receipt in December expense report (if your company allow to include old expenses in new reports)
Hope it helps.
- Mute
- Subscribe
- Bookmark
Hi @cupshur
- Go to Concur
- Go to Expense
Hope it helps.
- Mute
- Subscribe
- Bookmark
It did help. Thank you so much for your help.
- Mute
- Subscribe
- Bookmark
@cupshur if the report status doesn't show Sent for Payment, you should be able to recall the report to make your changes. If it is Sent for Payment, then it cannot be recalled or changed.
