- Mute
- Subscribe
- Bookmark
How do I upload an attendee list to add to an expense - 260 attendees
Hi
I have 260 attendees to add to an expense. How do I import a list please?
Thank you
Anne
- Mute
- Subscribe
- Bookmark
It affects lost of us. Having to add guests who are NOT in Concur, is all good and fine if an expense report is 10 people or less, but most of us deal with major lists of people, making sitting down and inserting one person at a time for a list of 10--1000 people ridiculous. Concur really needs to create a function that allows for mass downloading of names (and maybe, if they're so finicky about no repeats, have the download ask about repeats as the system finds it? It's a standard feature now of most systems).
- Mute
- Subscribe
- Bookmark
You can import attendees in bulk.
Navigations:
1. Create expense entry
2. Click on Attendees option as shown below
3. Click on Add button
4. Click on Import Attendees option and download template
5. Open downloaded template and update it with attendee details as show below.
6. Upload template using Upload Spreadsheet option and click next, next, done.
7. All attendees will get added successfully.
Also, system will give pop-up msg after uploading sheet if there are any duplicates as shown below. This duplicate check is based on the backend attendee type configuration. Example, If check is configured on first name and last name and company name then system will reject all such records where first name, last name and company name is same for multiple records.
Please note that duplicate check criteria could be configured differently for each attendee type. It is totally based upon, how configuration is done in backend. Based on that system will behave and in such cases, system will skip duplicate records during upload.
You can refer to the below similar case for more info. Search below subject.
Attendee Import - Skipping Records Based on Duplicate First Name and Title
- Mute
- Subscribe
- Bookmark
Thanks Pooja, I wish I could, but I do not have the "import attendees" link as shown in your description (appreciate your replying!).
I know this means Concur was set up at my business in such a way that's not possible, so I have contacted them to see if they can add that feature. Once they do, I will definitely utilise this tool. Thank you!
