fayeth
Fleet Card feed supported vendors
Just want to confirm the supported vendors for fleet card integration. Our vendor is Krungthai Fleet Card.
samasuraj
Hi @fayeth
Topic: Fleet Card feed supported vendors
SAP Concur Professional Edition supports specialized Fleet/Fuel Card functionality.
Presently, the supported Vendors for Fleet Card integration is only:  WEX Fleet Card - Documented SAP Concur integration
Krungthai Fleet Card is not currently verified as a supported direct-feed provider for SAP Concur Expense.
Thanks & Regards
Samantha Prathikantam
fayeth
Hi @samasuraj,
Thank you for confirming that it is not supported for fleet card. Will just have to think of a workaround then.
