Just want to confirm the supported vendors for fleet card integration. Our vendor is Krungthai Fleet Card.
Hoi @fayeth
Topic: Fleet Card feed supported vendors - Workaround
As Krungthai Fleet Card is not supported for direct integration, the workaround is a controlled file-based import,
subject to SAP Concur's approval.
Workaround Steps:
Use manual fuel expense entry with receipts for immediate needs, while SAP Concur evaluates an approved Krungthai feed or third-party integration.
Thanks & Regards
Samantha Prathikantam
Hi @fayeth
SAP Concur Professional Edition supports specialized Fleet/Fuel Card functionality.
Presently, the supported Vendors for Fleet Card integration is only: WEX Fleet Card - Documented SAP Concur integration
Krungthai Fleet Card is not currently verified as a supported direct-feed provider for SAP Concur Expense.
Thanks & Regards
Hi @samasuraj,
Thank you for confirming that it is not supported for fleet card. Will just have to think of a workaround then.
Hoi @fayeth
Workaround Steps:
Thanks & Regards
@samasuraj manual card imports is not supported in Concur Expense. This was done away with several years ago. Please edit your response.
Hi @fayeth
Thank you for marking my response as an Accepted Solution!
I am glad the information was helpful in resolving your issue.
Happy to help! 🙂
Thanks & Regards
