Kellen
CTE_SETUP - Integration Wbs Element
Hi
A Customer wants to change the Cost Object Hierarchy in
CTE-SETUP - Project WBS Element - Change Export - Cost Object Hierarchy.
They would liket to chanhe the List Level One (Logical System) to Employee ID but system is showing a error.
Can you let me know if it is possible to make this change? Or this list should always be Logical System as first level?
Can you let  me know more details about this integration?
Kind regards,
Kellen
@Kellen hello there. As a Certified Implementation Partner, any questions you have should be submitted to our Partner Support Portal. As a CIP, you have a dedicated Support team just for you, so any support that you need should be submitted to our Partner Support team.
Our Partner team has been very clear that our CIPs should be using the Partner Support portal. If you have never accessed the Portal, you will need to speak with someone at your company who has and they can submit your name to gain access.
