- Mute
- Subscribe
- Bookmark
Bank Feeds
Hi - is there a current issue with Bank Feed data not being imported into Concur?
It would appear that our corporate users have not had any bank transactions come through on their profile since the start of November?
- Mute
- Subscribe
- Bookmark
@Jules_D Thank you for reaching out here! Are you referring to your Mastercard? If so, I do show that on 11/1/23 there were transactions that were imported. Let me know if you are referring to something else.
Melanie Taufen
- Mute
- Subscribe
- Bookmark
Hi Melanie - I mean the entire company. We have 60+ credit card users and no transactions have been imported via the bank feed since the start of November (other than the balance owed direct debit from the bank which is what you are mentioning above which occurs at the start of the month). I have had several users who travel extensively who are reporting that there is a problem as there are no bank transactions coming through via bank feed. I can also confirm this as I have looked at various individuals profiles.
- Mute
- Subscribe
- Bookmark
@Jules_D Thanks for posting in the SAP Concur Community. Have you checked with your bank to see if they are sending the transactions and how frequently? I would recommend that you open a case in the SAP Concur Support Portal as an Authorized Support Contact. I am only seeing one credit card job in your configuration (if you are still with the company that your SAP Concur Community profile is under) and I see a credit card feed job that appears to be disabled.
Lee-Anne Dautovic
