rkushwah
Add link in Concur screen
Hi Team
Would it be possible to add any link on attached screens of concur?
@rkushwah I don't believe those screens are customizable. What are you looking to provide in the link? There may be another option that could work.
rkushwah
Could we add a link that directs users to an Excel file containing the list of available Expense Types and their corresponding usage guidelines for each Assignment Policy?
For example, if an employee selects the Long-Term Assignment Policy, the link should open a document showing only the expense types that are applicable to the Long-Term policy, along with a brief description of when each expense type should be used.
This would help employees select the correct expense type and reduce submission errors.
@rkushwah that isn't possible, but there is now an Expense Type tool tip feature you can use to provide users help in choosing the correct expense type.
