Who Me Too'd this topic
Keith77
Expenses Changing Cost centre default search from Text to Either
When setting up a List Management item you can only select Default search and Displays format as  Text or Code. But in the field for that selection in expenses form, there is a option for Either.
By allowing the Either to be set as default in the List Management screen,  End users could then search by either code or text without the need to change the search,  reducing input errors or the need to contact internal support to find the correct information
