Who Me Too'd this topic
monteypoo
Is there a way to make a list of suppliers inactive through using the import template?
I have a list of suppliers that I would like to make inactive in Concur, I don't want to delete them. In the import template I see that there is a field where the supplier can be flagged Y/N for deletion, but there doesn't appear to be a field flagged for activation/deactivation. I would like to check if it's possible to make suppliers inactive in this way, I'm wondering if perhaps the field is hidden from the import template and can be manually added?
Many thanks
