Who Me Too'd this topic
tesh94
Same Login ID in two different Concur instance (SSO enabled)
Is it possible to add the same user to two different set of Concur instances (different company ID).
Employee A ([email protected])
Concur Instance 1:                                  Concur Instance 2:
- Travel user                                             - Expense User
The Login ID has to be the same due to Single Sign On being enabled but then since it is the same, Concur is not allowing the employee to be imported into the second Concur instance. Does Email Aliasing help in this case?
- [email protected]               - [email protected]
Thanks.
Pritesh Jit Singh
