Who Me Too'd this topic
Nancyagfa
Accessing past reports
Has anyone else noticed that when trying to find past reports that the "All Reports" selection is missing?  At times I am asked to review past reports for auditing and this is time consuming when you have to go thru this Date Range step.  And once you do that, the report list does not stay up and you have to go back and do it all over.  This increases the admin time needed to do the required function.  By the way, the selected report list does not stay up for any of the choices so once you select the report to view, you will need to go over the same steps to get to the same place and view another report.
In the previous UI, the list of reports stayed up until you changed the selection or went out of the manage reports tab.  While I now can use the browser back arrow and go back to the list, it does not help if you click on Manage reports because that cancels the selection.  At this point it is annoying since I want 2021, but last year is now 2022.  Just venting that it makes it more difficult to look back at reports for audits.
Nancy Murray
Agfa
