Who Me Too'd this topic
TX_Princess_KK
Can you print a sorted Detailed Report?
Is there a way to print the Detailed Report in your chosen sort order? I often have large reports that I will sort by amount and match up to a spreadsheet.  However, when I print the Detailed Report it does not print out in the same order the expenses were sorted in, whether I used the amount, date or expense type.  Is there a way to do this?
