Who Me Too'd this topic
jerielderbsci
Edit Search for Flights - Time frame should stay the same
Hello Concur Team-
When I'm searching for flights that have multiple airports in the area it would be great if when I clicked Edit Search the timeframe I had selected didn't change every time I change the airport.  BTW the slider to select time frame sucks and needs to be put back to selecting the time or typing it in.  The slider is annoying and difficult to use.  Why do you all have to change the entire look of the flight search too?  The matrix at the top was much better than what you have changed it to.  Stop making changes nobody asked for.  It's not helpful and makes you and your product look like you don't listen to your customers.
