Who Me Too'd this topic
luning-zhou
API Uploaded Receipt Image Flagged as "Missing Timestamp" (Japan Client)
I am facing an issue when uploading receipt images to expenses via the Concur API for a client in Japan.
Here's my current process:
  1. I create an expense entry using the Expense Entries v3 API.
  2. Then, I use the Receipt Image v1 API to post an image to this expense.
The Problem: The image successfully appears in the Concur UI. However, it is flagged with the following error message: "領収書画像にはタイムスタンプが必要です。(Receipt image requires a timestamp.)".
My client uses Concur in Japan, and I understand this error relates to Japan's Electronic Bookkeeping Act (電子帳簿保存法) requirements for digitized receipts.
My Question: How can I ensure that receipt images uploaded via the Concur API are correctly timestamped or otherwise meet the necessary compliance requirements for Japan?
  • Is there a specific API parameter or a Concur configuration setting that needs to be enabled for API-uploaded images to be automatically timestamped or validated for Japanese compliance?
Any insights or guidance would be greatly appreciated.
