Support Phone Number
For Administrators and Authorized Support Contacts:
Call +1 855-895-4815 and select the Authorized Support Contact option from the menu. See more information.
For End Users:
To see what your support options are, please read: SAP Concur Support Overview.
What is Drive and How Do I Set Up Drive?
0 11.7K
What is Drive?
Drive is an effortless way to capture and expense car mileage. Using a combination of technologies, Drive captures mileage for you – meaning you no longer need to mess with your odometer and manually input routes.
Click Getting Started for more information.
How do I set up Drive?
If your company uses Drive, your employees can use GPS to track their travel – either manually or automatically on their mobile device. The SAP Concur mobile app captures their route data, then makes it available in Concur Expense. Here they can select the segments to add to an expense report.
Click Setting Up Drive to access the Drive user guide.
Watch a short demonstration on setting up drive by clicking the video below.
