Getting Started Guide
3 2 8,314
Our Getting Started Guide is a specially curated list of content to help you hit the ground running once your reporting tool is ready. You can use this guide to help sift through all the information provided in the SAP Concur Community so you know where to start.
2 Comments
swessels
You can no longer access the Standard Reporting Guide through the link on this.  I cannot seem to locate this anywhere, it just takes you back to the general support page (very frustrating).
dbrandywatling
The Standard Report Catalog was recently moved to the SAP Help Portal. Please use the search function on the help portal to search for Standard Report User Guide. This will take you to the catalog now housed on the help portal.
About This Author
