Re: Concur Mobile App Log in not work
I am having the same issues having changed phone from Nokia8 with Android 9. On the old device user name and password work. On the new one Nokia8.1 with Android 9 it does not work, with a message "unable to login". I also tried on an iPhone6 and iOS13, and was unable to login this time getting a "password has expired" message!!!
Help!!
Hi @emadili  @desmorrissey
Good day.
Are you still not able to log on to the app? Kindly share to me your login ID so I check and do a remote wipe of your mobile PIN.
Thank you
AnnaDizo
Same issue. How can I send you my user iD?
Anna
Do you understand that the credentials work from another Nokia phone with the same Android 9 OS??? I suspect there must be some incompatibility issue we with the Android OS deployment or some issue maybe related to the fact my company uses Company Portal from MS?
hello,
i cannot log into the sap mobile app and have tried ressetting both password and pin but none log into the app. webpage access i stsill fine
Any update  still no solution!
Hi All,
Thanks for resourcing the SAP Concur Community for this issue.
We are no longer wiping phones directly from conversations happening here on the community. You will need to create a support case to get mobile errors resolved.
Here are two ways to get support:
  1. You can contact your company’s authorized support contact. They will be able to help you create a support ticket for this issue. Your company should be able to tell you who they are and provide contact information.
  2. If your company subscribes to User Support Desk you can call them directly and create a support ticket. Your company will be able to tell you if this is an available support channel and provide you with the number.
For more general information on logging into your mobile app check out this video:
I hope this helps!
Ashley Bragg
I have been using the mobel app for a year now with no issues.  I now am unable to login on my iPhone11 and my iPhone8.  Says it does not recognize my username.  I can login just fine from the website.
Any help would be appreceiated
AB
ourRe: Concur Mobile App Log in not work
quite useless video
your mobile app has clearly HUGE log in problems, looking at the amount of messages here
you need a super bug resolving them...
While I appreciate you referring us to reach out to our company administrator on creating a suport ticket, it is a big inconvenience for your users to generate help desk tickets when this seems to be a frequent problem on your end.  I'm having this same issue where I can't login on my mobile app but can on my desktop.  Often times the problem fixes itself in a few days, but this time no such luck.  I'm trying to get my expense report filed and we were sold on the convenience of this app.  I now need to synch my phone up with my laptop and dig through picture albums to try and attach the correct receipts....it's just a hassle and I can see this has been a problem on your end for quite some time.....will there ever be a permanent fix to this issue?  Telling me to contact my administrator so they can issue a help desk ticket isn't quite the resolution I would expect when multiple people are having the same issue.
