hello
could you help me to find where o can't eliminate the second approver of the below employee in which part of concur administration i can't do this?
@chery9 this isn't based on the employee, it is based on your Workflow as it looks like you have Authorized Approvers set up. You would need to remove the Authorized Approver workflow step. However, doing this would do it for all other employees that use that policy. You could exclude one employee from the workflow step, but that isn't recommended.
Why do you not want an authorized approver to review and approve this employee's report?
hello kevin yes i want only one approver not the second only dilan have to appear on there
