fvultee
"Please choose a stronger password" Issue
Hello all,
I was just trying to update my password, and I'm getting the popup: "Please choose a stronger password".  I get this error no matter what I type, and it's not a password strength issue.  I'm not using things like 1234 and monkey123, here is an example of a password I've tried, all are of similar complexity:
@YX%27V8EDx8%r*MFABwpVBMJkrsCZc#9TEYe
Anyone know why this is happening?
MelanieT
@fvultee Does it give you suggestions or let you know what is missing?
Melanie Taufen
fvultee
@MelanieT, no suggestions are offered, and it says "VERY STRONG PASSWORD" when I put in the new 20ish character password.  When I click OK to change it, it gives me this:
@fvultee are you still having an issue with this?
fvultee
Yes, I am still unable to change the password from within the Concur site due to the message "Please choose a stronger password."  I'm assuming this has to do with the fact that my company uses single sign on so perhaps when this is set up the ability to change the Concur password is just not available.  Either way, no loss in security since I can't sign on with a Concur password anyways.  Regards.
