When a Vendor changed the Entity, do you suggest creating a new Vendor ID? For example, a vendor was set-up as a Sole Proprietor but changed their entity to a S-Corporation. Should I just update the current Vendor profile or should I create a new Vendor ID?
@maria2 I think as long as nothing the vendor changed would affect your ability to make payments to them, you could just update the current vendor.
