Vipul
Unable to look for flights
There is no option for me to look and book the flights.
The homepage that I am seeing after login in is different than what is shown in Helpcenter documents for booking of flight. At my end there is no option to look for the flights. Also, I am unable to share the screenshot in here.
MelanieT
@Vipul I was able to look up your profile and you are only set up as an Expense User, not a Travel user.  If you should be, you will want to reach out to your Admin or your manager to see if you should have the Travel Role.
Melanie Taufen
MelanieT
Melanie Taufen
