nlynch91
Testing Scenarios for Concur verify
Hi All,
We are in the testing phase of Concur verify. Can you please advise of some test scenarios that would be good to use.
Many thanks,
Niall
Hi @nlynch91 ,
I have never worked on Concur verify before. However, sharing below link from help portal.  Check if this is helpful.
Library of Audit Checks | SAP Help Portal
Hi @nlynch91 ,
nlynch91
Thanks Pooja
