elainefoo
Standard Import fields
For this, is there any column for policy name?
samasuraj
Hi  @KevinD
Oh, ok. Thank You for letting me know. 🙂
Hi  @elainefoo
Topic: Standard Import fields
In SAP Concur Professional Edition, the Standard Employee Import does not have a generic Policy Name column.
Policy assignment is generally controlled through the Employee's Expense Group, which is associated with the applicable expense policy.
Please verify the supported group-assignment field in your specific import template.
Thanks & Regards
Samantha Prathikantam
samasuraj
Hi @elainefoo
SAP Concur Standard Edition:
The Employee/User Import supports an Expense Policy Group field, rather than a generic Policy Name field.
Administration → Expense → Policy Groups (under Product Settings).
1.  Expense Policy Group: Assigns employees to the appropriate expense policy group.
2.  Value: Use the configured Policy Group Code, not the display name.
SAP documentation confirms this field is available in the relevant Standard Edition user import.
Thanks & Regards
@samasuraj this person is actually on our Professional edition, not the Standard edition. 🙂
samasuraj
Hi  @KevinD
Hi  @elainefoo
Thanks & Regards
@elainefoo which import template are you using?
elainefoo
List Import_OT_Co Hierarchy
