- Mute
- Subscribe
- Bookmark
Sap concur
Je peux pas rejoindre mon compte SAP concur même si mon adresse mail de decathlon et le mot de passe sont correct !
les mots de passe sont sensible à la casse !! C est ça le probleme exactement ! Merci de me répondre le plutôt possible .
- Mute
- Subscribe
- Bookmark
@aminekhoubi I looked up your name and email and didn't find an SAP Concur profile for you. Your company will need to create one for you. I suggest speaking with your direct manager/supervisor to get a request submitted for a profile.
- Mute
- Subscribe
- Bookmark
@aminekhoubi when you try to access SAP Concur, what username are you entering? Also, passwords would be case sensitive. Your username is not case sensitive, but your password must be entered exactly as you created it.
- Mute
- Subscribe
- Bookmark
Merci @KevinD pour le retour
Mon noms utilisateur c est aminekhoubi , moi j ai pas encore rejoindre la plateforme avec mon compte mail professionnel de decathlon.
- Mute
- Subscribe
- Bookmark
@aminekhoubi the username you have here on this community isn't the username you would use to access SAP Concur. This community (community.concur.com) is a completely different site from SAP Concur (www.concursolutions.com).
- Mute
- Subscribe
- Bookmark
