- Mute
- Subscribe
- Bookmark
SAP Concur API Integration
I want to connect SAP Concur using concur endpoint URLs, going through the documentation what I understand is we will need to have Client web services subscription, so that we can enable OAuth 2.0 application management tool.
CWS subscription costs around 500 USD/month. Is there any other way we can do the API integration?
Thank You,
Souradip Dutta
- Labels:
API
Sign In Issues
- Mute
- Subscribe
- Bookmark
Hi @souradip_dutta , you can also use ICS - What is SAP ICS? - SAP Concur Community. We also have API calls there.
About OAuth 2.0 application, by default we do not allow the customers to enable this feature. Probably you would need to ask separate access describing your business requirement.
Best wishes,
Andras
- Mute
- Subscribe
- Bookmark
Best wishes,
Andras
