jgarcia
Login Warning - REAL ID
Hi CONCUR community,
I am trying to add a hyperlink to the Login Warning pop-up box.
This is what I have so far:
<b>***On May 7, 2025, U.S. travelers must be REAL ID compliant to board domestic flights and access certain federal facilities.***</b>
• Find out if you’re REAL ID ready with the Department of Homeland Security interactive tool!
We want a hyperlink to: https://www.dhs.gov/real-id
How do I add that to the word "tool"?
Besides help on the hyperlink, curious to know what others are doing with their messaging?
Jess
The Broad Institute
@jgarcia I looked this up and the login pop-up only accepts text. It doesn't allow for hyperlinks. So, you would need to just enter the entire URL as text.
millerbrett114
Embed this on your "Login Warning" message
<a href="https://www.tsa.gov/real-id"> Tool</a>
Brett M.
crystalreports
We place the REAL ID information under Company Info, so it is always available from the Concur homepage for our users to see.
