nedimyilmaz
Invalid Currency on Employee Export
Hi All,
There is an error while exporting employees on CTE_MONI transaction.
The system says invalid currency but I couldnt find whats wrong in the company/employee/personnel area master datas. By the way when I try the other employees on the same company code there is no issue, only this employee got some problem.
If you have any ideas, I am open to get valuable advices.
Kind regards,
Nedim
nedimyilmaz
There was need to be change customizing related table T500P-MOLGA with selecting appropriate Country Grouping(MOLGA).
Then its solved. I want to update here, many thanks.
Kind regards,
Nedim
@nedimyilmaz could you send me a private message with the employee name. I'll take a look and see if I find anything. To send me a private message, click my username (KevinD) then the Message button.
nedimyilmaz
Kind regards,
Nedim
