Julieta90
Enterprise Location
Hi, does anyone know if the Enterprise car rental location at Elvas Ave in Sacramento was removed? When I try to search for this location, I only get the 12th Street location.
@Julieta90 you might want to Google it and give them a call. That will help narrow down whether they are permanently closed or if there is some issue causing them not to show.
