enickle
Difference between ADV AP/GL extract and ADV Custom Axapta GL
We currently use the ADV AP/GL extract for NA, which is automated and is delivered into our AX systems for accounting.
I have been given the task of automating the same process for our APAC China extract, which is the ADV Custom Axapta GL.
What is the difference between these two types of files?  What should I be looking for during this process?
Sorry newish to Concur, and I'm still learning the ropes here.
I appreciate any advise.
@enickle I recommend requesting to join the admin group and then posting your question there. You are more likely to get a response from that group rather than this forum.
To be admitted into the Admin Group, you do need site admin permissions at your company, which I do verify. 🙂
