jainh
Company Notes - UI Art of Possibility
Hi Everyone! I am looking to see examples and what is possible to setup the Company Notes so it provides a good user interface and experience for our users.
Here are my ideas and challenges:
1. The text doesn't adjust based on users screen resolution, there is always white space.
2. I would like to create 2 or 3 column layout with image so its better UI to draw attention.
3. See how else others have setup to communicate to their users key information that is important for them to know.
10 REPLIES 10
@jainh one thing I can tell you is that for a two or three column layout, you will need to use the Source Code option to create a table using HTML. See my screenshot below with the Source Code option highlighted.
You can Google how to create a table using HTML. It is pretty straightforward once you see how it works.
I'll let others add what they have done for their Company Notes.
MICHAELPARSONS
I thought HTML use in Company Notes was discontinued a while back.  Is it allowed again?
@MICHAELPARSONS I don't recall ever hearing this. I just did a test of adding a table using HTML. See my screenshots.
Hi @KevinD
Today I had to make a change, and when I tried to edit it using the Source Code option, I couldn't. I opened a case on the Support Contact website:
Case-26177550-Company info section of the Travel module
BR,
cj
  Best Regards,
  CJ
@cjmarimo did you use the Source Code option when you originally added the content to the Company Notes?
hi @KevinD I created this company note directly from the source code. Or at least that's how I remember it.
BR,
cj
  Best Regards,
  CJ
Hi @KevinD
Yes of course, the code is there.
Now I've seen what the problem is: the "Appearance Settings" selected.
For "Evening Horizon" and "Horizon High Contrast Black," the contrast between the background and the font is almost zero, which is why it's not visible.
BR,
cj
  Best Regards,
  CJ
@cjmarimo good catch.
KFriedhoff
Hi @cjmarimo
How did you get just the top row blue? Every time I try, it colors the entire table. 😕
Karen
Hi @KFriedhoff
I have defined the color in the table header.
<tr>
<th style="background-color: #005cb9; border: 1px solid #1a85ec; color: #ffffff; font-family: 'Helvetica Neue', Helvetica, 'Segoe UI', Arial, sans-serif; font-size: 12px; font-weight: normal; padding: 1px; width: 43%;">Cambios y cancelaciones de las reservas</th>
<th style="background-color: #005cb9; border: 1px solid #1a85ec; color: #ffffff; font-family: 'Helvetica Neue', Helvetica, 'Segoe UI', Arial, sans-serif; font-size: 12px; font-weight: normal; padding: 1px; width: 28%;">Viajes</th>
<th style="background-color: #005cb9; border: 1px solid #1a85ec; color: #ffffff; font-family: 'Helvetica Neue', Helvetica, 'Segoe UI', Arial, sans-serif; font-size: 12px; font-weight: normal; padding: 1px; width: 28%;">Formación</th>
</tr>
BR,
cj
  Best Regards,
  CJ
