- Mute
- Subscribe
- Bookmark
An employee fails to resolve to a valid EmployeeHierarchyService configuration hierarchy node
Does anyone know how to resolve the above error message?
- Mute
- Subscribe
- Bookmark
@ccunnido Hi! This can be caused by one of the following:
- Value in the import file does not match the list Item Code from Employee Hierarchy Source List.
- Invalid value provided in Custom 21 field (column 42) within 300/305 record employee import file.
- Item Code in the import file does not exist in the Source List.
- If the list item is found, make sure that the exact Item Code is used in the import file, then re-import.
- If the list item is not found, add it to the list, then re-import the file.
Make sure that when you are updating fields you are using the item code, not the name of of the list item.
Melanie Taufen
