crystalreports
Account String - 11 level deep
We currently utilize a six-level connected list using the org_unit fields for our account string . We are looking to increase that to 11 levels.
Does anyone know if this is possible and anything that we should be considering?
MelanieT
@crystalreports The import allows for 10 levels, as that is the max that we suggest.  A few things come to mind though with having multiple levels.
*Makes using audit rules/workflow rules harder as you have to drill down to each level (10x's)
*You will have to have 10 Custom fields available on each form you plan on having this account string on (Employee, Report Header, Entry, Allocation)
*Makes for a lot of fields for the user to populate at different levels
Let us know if you have more questions!
Melanie Taufen
